[Qgis-user] Error when "save as" the dataset
Andrea Peri aperi2007 at gmail.com
Tue Sep 29 08:33:41 PDT 2015
I notice that in the qgis 2.10.
When try to export using "save as" a shapefile.
I have an error from ogr:
Esportazione nel file vettoriale fallita.
Errore: Errori nella scrittura dell'elemento:
Geometria dell'elemento non importata (errore OGR: )
In english
Exportation in the vector file faildes
Error: errors in the write:
Geometry of the elements not imported (OGR error).
I notice also that if I select a few elements and repeat the save-as
using ony selected elements.
All go ok.
Instead if I select ALL the elements of the dataset and try the export with
save-a (using selection)
have again the ogr error.
Perhaps a memory error ?
I'm use wndows 7 and qgis-2.10 32bit.
Should I open a ticket for qgis 2.10 ?
Thx.
Andrea Peri
qwerty àèìòù
