[Qgis-user] variables in postgis filters
Sandro Santilli
strk at keybit.net
Tue Apr 5 01:20:19 PDT 2016
On Tue, Apr 05, 2016 at 06:09:12PM +1000, Nyall Dawson wrote:
> What's the topology issue you're hoping to solve with this?
Topology face layers from the TopoViewer (via DBManager plugin)
use an expensive (and volatile, thus non-indexable) query to
generate the geometry to be used for display. The provider generally
applies the spatial filter to the geometry field, which in this case
is ineffective.
I could fix this by adding the possibility to specify a
"spatial-filter-field" which is different from the "spatial-display-field"
(similarly could be done for obtaining the $area from the provider,
for example).
Or there could be a way for a query to include its own
scale-and-extent-dependent filter to be applied when fetching
geometries. This would be more flexible for the user as it could
specify any arbitrary filter that could serve to modify what's
fetched depending on the viewport (which could even include
calling functions that query different tables based on different
viewport scales, for instance).
--strk;
