[Qgis-user] no data in raster calculator NDVI
    Mariana Buzzi
    marianabuzzi86 at gmail.com
    Tue Apr  5 07:47:26 PDT 2016
Thanks Nicolas!
But...I check the CSR and It is right. I didn“t work with more than one
layer...
Any idea please!???
Regards,
Mariana
2016-04-05 10:20 GMT-03:00 Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
> Hi,
> I don't use NDVI raster calculation but if you have no data values where
> you thinks you have some data, then my first reaction would be to see if
> all the layers are in the same CRS in case the plugin does not reprojection
> on the fly...
> You are using more than one layer?  Maybe add information  on what exactly
> you are doing. That would help others help you.
> Cheers!
> Nicolas
> Nicolas
> On Apr 5, 2016 08:45, "Mariana Buzzi-2 [via OSGeo.org] " <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5259730&i=0>> wrote:
> Hi everybody!!!!
> I'm doing a calculation with NDVI raster calculator. When I generate the
> calculation results I get a lot of pixels without values (no data). How I
> can do to fill those values with data?
> Thank you so much!!!!
> Regards,
> Mariana
> Qgis-user mailing list
> <a
> href="/user/SendEmail.jtp?type=node&node=5259726&i=0">[hidden
> email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/no-data-in-raster-calculator-NDVI-tp5259726.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
> here.
> <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>"
> style="font:9px serif">NAML
> View this message in context: Re: no data in raster calculator NDVI
> <http://osgeo-org.1560.x6.nabble.com/no-data-in-raster-calculator-NDVI-tp5259726p5259730.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160405/26523173/attachment.html>
