[Qgis-user] Metasearch plugin problem
Tom Kralidis tomkralidis at gmail.com
Thu Apr 7 07:38:28 PDT 2016
Vicent: what version of MetaSearch is being used (see top left of
MetaSearch main window)? Can you provide the CSW URL in question?
On Thu, Apr 7, 2016 at 10:28 AM, Vicent García
<vicent_montesa at hotmail.com> wrote:
> Yes, I can
> The screenshot attached in this message is a good example.
> Vicent
>> Date: Thu, 7 Apr 2016 09:50:49 -0400
>> Subject: Re: [Qgis-user] Metasearch plugin problem
>> From: tomkralidis at gmail.com
>> To: vicent_montesa at hotmail.com
>> CC: qgis-user at lists.osgeo.org
>> Hi Vincent: thanks for the info. Unfortunately I am unable to reproduce
>> the issue. Can you provide screenshots?
>> On Wed, Apr 6, 2016 at 6:06 PM, Vicent García
>> > Of course,
>> > First, open the Metadata Catalog Plugin and put a default catalog
>> > service (whatever you want).
>> > Then, search for a wms typing "wms" on the search box
>> > Next, click on a service/dataset which has no the possibility to add it
>> > into QGIS using the WMS/WMTS button
>> > Finally, click twice on the selected service/dataset and the message
>> > will appear automatically. That's my case.
>> > Let me know if you have any doubt.
>> > Vicent.
>> > -----Mensaje original-----
>> > De: tom.kralidis at gmail.com [mailto:tom.kralidis at gmail.com] En nombre de
>> > Tom Kralidis
>> > Enviado el: dimecres, 6 d’abril de 2016 23:56
>> > Para: vicent_montesa at hotmail.com; qgis-user <qgis-user at lists.osgeo.org>
>> > Asunto: Re: [Qgis-user] Metasearch plugin problem
>> > Hi Vincent: thanks for the info. Can you provide steps and the URL of
>> > the CSW so I can try to reproduce?
>> > Thanks
>> > ..Tom
>> >> ---------- Forwarded message ----------
>> >> From: Vicent García <vicent_montesa at hotmail.com>
>> >> Date: Wed, Apr 6, 2016 at 4:46 PM
>> >> Subject: [Qgis-user] Metasearch plugin problem
>> >> To: qgis-user at lists.osgeo.org
>> >> Hi everyone,
>> >> I’m having troubles to run Metasearch CSW plugin on QGIS 2.14. When I
>> >> find a dataset/layer which can’t be added as a wms layer directly, I
>> >> click on the dataset located on the list in order to obtain more info
>> >> about the data, but a python error message appear inmediately. Typical
>> >> error displayed is: “<<selected_dataset>> has no attributes”.
>> >> I’m using Lubuntu as a OS.
>> >> Vicent.
