[Qgis-user] Metasearch plugin problem
Vicent García
vicent_montesa at hotmail.com
Thu Apr 7 08:32:55 PDT 2016
Tom,
Don't worry, I found the problem!
The problem was related to the catalog URL which I've copied from the Internet. I've copied it wrong.
I solved the problem creating a new connection.
That's all.
Thanks for your patience and sorry. It was my mistake.
Vicent.
To: tomkralidis at gmail.com
Subject: RE: [Qgis-user] Metasearch plugin problem
Date: Thu, 7 Apr 2016 15:13:18 +0000
OK, this is the moment before the python error message appears.
Then, I click twice on the selected record and the problem appears. I can't view more info about the dataset or service.
Vicent.
> Date: Thu, 7 Apr 2016 11:03:48 -0400
> Subject: Re: [Qgis-user] Metasearch plugin problem
> From: tomkralidis at gmail.com
> To: vicent_montesa at hotmail.com
> (offlist)
> Vicent: FYI this works for me. What are the exact terms you are using
> to search? Can you send a screenshot of the what the results screen
> looks like before clicking on a record?
> On Thu, Apr 7, 2016 at 10:43 AM, Vicent García
> <vicent_montesa at hotmail.com> wrote:
> > The version is 0.3.4.
> > The URL of the web catalog is (I guess that you want this one):
> > http://www.idee.es/csw-inspire-idee/srv/spa/csw?REQUEST=GetCapabilities&SERVICE=CSW&version=2.0.2&request=GetCapabilities&service=CSW
> > Vicent
> >> Date: Thu, 7 Apr 2016 10:38:28 -0400
> >> CC: qgis-user at lists.osgeo.org
> >> Vicent: what version of MetaSearch is being used (see top left of
> >> MetaSearch main window)? Can you provide the CSW URL in question?
> >> On Thu, Apr 7, 2016 at 10:28 AM, Vicent García
> >> > Yes, I can
> >> > The screenshot attached in this message is a good example.
> >> > Vicent
> >> >> Date: Thu, 7 Apr 2016 09:50:49 -0400
> >> >> Hi Vincent: thanks for the info. Unfortunately I am unable to reproduce
> >> >> the issue. Can you provide screenshots?
> >> >> On Wed, Apr 6, 2016 at 6:06 PM, Vicent García
> >> >> > Of course,
> >> >> > First, open the Metadata Catalog Plugin and put a default catalog
> >> >> > service (whatever you want).
> >> >> > Then, search for a wms typing "wms" on the search box
> >> >> > Next, click on a service/dataset which has no the possibility to add
> >> >> > it
> >> >> > into QGIS using the WMS/WMTS button
> >> >> > Finally, click twice on the selected service/dataset and the message
> >> >> > will appear automatically. That's my case.
> >> >> > Let me know if you have any doubt.
> >> >> > Vicent.
> >> >> > -----Mensaje original-----
> >> >> > De: tom.kralidis at gmail.com [mailto:tom.kralidis at gmail.com] En nombre
> >> >> > de
> >> >> > Tom Kralidis
> >> >> > Enviado el: dimecres, 6 d’abril de 2016 23:56
> >> >> > Para: vicent_montesa at hotmail.com; qgis-user
> >> >> > <qgis-user at lists.osgeo.org>
> >> >> > Asunto: Re: [Qgis-user] Metasearch plugin problem
> >> >> > Hi Vincent: thanks for the info. Can you provide steps and the URL of
> >> >> > the CSW so I can try to reproduce?
> >> >> > Thanks
> >> >> > ..Tom
> >> >> >> ---------- Forwarded message ----------
> >> >> >> From: Vicent García <vicent_montesa at hotmail.com>
> >> >> >> Date: Wed, Apr 6, 2016 at 4:46 PM
> >> >> >> Subject: [Qgis-user] Metasearch plugin problem
> >> >> >> To: qgis-user at lists.osgeo.org
> >> >> >> Hi everyone,
> >> >> >> I’m having troubles to run Metasearch CSW plugin on QGIS 2.14. When
> >> >> >> I
> >> >> >> find a dataset/layer which can’t be added as a wms layer directly, I
> >> >> >> click on the dataset located on the list in order to obtain more
> >> >> >> info
> >> >> >> about the data, but a python error message appear inmediately.
> >> >> >> Typical
> >> >> >> error displayed is: “<<selected_dataset>> has no attributes”.
> >> >> >> I’m using Lubuntu as a OS.
> >> >> >> Vicent.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160407/a7508003/attachment.html>
