[Qgis-user] Use of file with ".flt"extension
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Thu Apr  7 09:07:07 PDT 2016
Hi,.hdr is most a header text file that you can open with a txt editor like notepad++.  Apparently, you can open the .flt (float point raster) if you modify it to a .BIL.  See link.CheersNicolas
http://gis.stackexchange.com/questions/140389/converting-dem-to-floating-point-raster-flt-using-qgis
To: nicolas.cadieux at archeotec.ca
Date: Thu, 7 Apr 2016 09:36:59 -0600
Subject: Use of file with ".flt"extension
	Hello ,
I'm working with the "Global width database for large rivers" which I've downloaded . The package includes a number of files . The one I can visualise on QGIS is the ".flt" one and it has got a ".hdr" file with.
the question is how can i use this ".flt" file so as to work with it in Qgis. I found that it needs to be converted to a format know by QGIS , and that this file contains binary 32 bits format I guess.
Any syggestions how can I work with this file ?
Thank you so much
SAFNAJ Imane Élève ingénieur en double diplôme à Grenoble-INP ENSE3 Tél: +33 6 64 39 46 35 [hidden email] Auparavant : Ingénieur en Hydraulique de l'Ecole Hassania des Travaux publics
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Use-of-file-with-flt-extension-tp5260163.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here.
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Use-of-file-with-flt-extension-tp5260163p5260169.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160407/efcb3f0b/attachment.html>
