[Qgis-user] Clip - unsupported geometrytype -2147483646
Alex M tech_dev at wildintellect.com
Wed Apr 20 12:40:38 PDT 2016
It's much easier than that. In the Save As dialog there is a Geometry
Type section. Change that from automatic to the specific type you want.
Then make sure to uncheck the "include z-dimension box" below it.
As an alternative ogr2ogr -dim 2 will also convert to 2d geometries.
I've tested both of them.
Long term obviously it should fixed in the code.
Thanks,
Alex
On 04/17/2016 04:51 AM, Lene Fischer wrote:
> Hi again,
> I now created a new temp Scratch layer – line copy/pasted all the lines from the original layer – saved as – and now it works.
> It would be great if there was an understandable error text ☺
> Lene Fischer
> Associate Professor
> Department of Geosciences and Natural Resource Management
> University of Copenhagen
> MOB +45 40115084
> lfi at ign.ku.dk<mailto:lfi at ign.ku.dk>
> [cid:image001.gif at 01D03029.2F3EC6A0]
> Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Anita Graser
> Sendt: 17. april 2016 12:24
> Til: ralfwessels
> Cc: qgis-user
> Emne: Re: [Qgis-user] Clip - unsupported geometrytype -2147483646
> I had the same issue with some polygon datasets today. Used a fixed distance buffer with distance 0 to "fix" the datasets.
> Best wishes,
> Anita
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
