[Qgis-user] Open geometryless tables from GeoPackage
Stefan Ziegler
stefan.ziegler.de at gmail.com
Wed Apr 27 22:03:45 PDT 2016
Yes, compiled and running against gdal master.
Do you just drag 'n' drop the geopackage file into QGIS? Do you mind trying
this one: http://sogeo.services/tmp/av_2495.gpkg
I checked it with "ogrinfo -so av_2495.gpkg" and it only shows the tables
with geometry (gdal 1.11 and gdal master).
regards
Stefan
On Wed, Apr 27, 2016 at 9:47 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le mercredi 27 avril 2016 21:25:04, Stefan Ziegler a écrit :
> > Hi
> > is there a working approach to open geometryless tables from a geopackage
> > file?
> Works for me with https://github.com/qgis/QGIS/pull/3031 applied, but
> there's
> nothing in it specifically to handle that.
> Is your QGIS build against GDAL 2.0 ? (1.11 cannot handle GPKG geometry
> less
> tables)
> > When opening a geopackage file with the standard dialog, there are only
> the
> > tables shown with geometries.
> > In the db browser the geometryless tables are shown but cannot be added:
> "/home/stefan/Projekte/qgis-ili2pg-workshop/av_2495.gpkg|layername=Einzelob
> > jekte_Einzelobjekt is an invalid layer - not loaded"
> > best regards
> > Stefan
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160428/fc47d516/attachment.html>
