[Qgis-user] trouble getting data from OpenStreetMap
Stephen Sacks
sacks44 at earthlink.net
Thu Apr 28 16:47:17 PDT 2016
Please excuse a naive question from a new QGIS user.
I have installed QGIS (version 2.14.1-Essen, code revision ea85bef) on
my Dell desktop running Windows 7 Home Premium. I've failed on my very
first task, namely to create a layer using data from OpenStreetMap.
Very carefully following instructions in the User Guide, I did the
following three steps:
1. Vector > OpenStreetMap > Download Data:
I chose Manual and entered longitudes -77.0 and -70.0, and lat's
44.0 and 41.0, which roughly encompasses New York and Massachusetts.
After some back-and-forth of the progress bar, an .osm file of size 337
bytes appeared on my hard drive and I got a message saying "Download
has been successful."
2. Vector > OpenStreetMap > ImportTopologyFromXML:
I selected the .osm file just created and accepted the suggested
file name for the .db output, and the connection name. The box next to
"Create Connection" remained checked. "Import has been successful"
message appeared immediately, and a .db file of size nearly 6 MB showed
up on my hard drive.
3. Vector > OpenStreetMap > ExportTopologyToSpatialLite:
I did this step three times, once for points, once for polylines,
and once for polygons. In each case, the input DB file was the db file
created in step 2 above. In each case, under Exported tags I chose Load
from DB, and in each case not a single tag appeared for me to choose
from. For each layer, I got an "Export has been successful" message.
However, when the three layers (points, lines, polygons) appeared in the
Layers Panel, all of them had zero feature count and all three attribute
tables are totally empty.
What am I doing wrong ? Why don't I see the streets of New
York and Massachusetts ?
Thank you in advance for your help. I'll be embarrassed if my
error is blindingly obvious.
Steve
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160428/9f3e8037/attachment.html>
