[Qgis-user] How to Build QGIS from source in Centos 6?
Matthias Kuhn
matthias at opengis.ch
Fri Apr 29 01:13:04 PDT 2016
Short answer: don't! QGIS 2.0.1 is really old, a lot of bugs have been
fixed since and a lot of new features have been introduced.
Long answer:
QGIS 2.0.1 is really old. It is not Qt5 compatible. If you want Qt5
support (which also means that you will have trouble to get your plugins
to work) you will need a newer QGIS version (and apparently build
dependencies like the ones you mention below).
You can also try to build with Qt4 dependencies. QGIS 2.0.1 INSTALL
states Qt >= 4.5 so it should be compatible with the (also really old)
Qt 4.6 version.
Matthias
On 04/29/2016 05:22 AM, 童言 wrote:
> I can't find the INSTALL guide on how to compile QGIS 2.0.1 from
> source for Centos platform. If I just do this on Centos 6 platform
> according to the guide for Fedora Linux, such as:
> dnf install qt5-qtwebkit-devel qt5-qtlocation-devel qt5-qttools-static
> qt5-qtscript-devel qca-qt5-devel python3-qt5-devel
> python3-qscintilla-qt5-devel qscintilla-qt5-devel
> python3-qscintilla-devel python3-qscintilla-qt5 clang flex bison
> geos-devel gdal-devel sqlite-devel libspatialite-devel qt5-qtsvg-devel
> qt5-qtxmlpatterns-devel spatialindex-devel expat-devel proj-devel
> qwt-devel gsl-devel postgresql-devel.
> I find there are no packages about qca-qt5-devel, python3-qt5-devel,
> python3-qscintilla-qt5-devel,
> qscintilla-qt5-devel, python3-qscintilla-devel and
> python3-qscintilla-qt5 for Centos 6, so what should I do now?
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160429/8886305a/attachment.html>
