[Qgis-user] Assistance with Basic Authentication
Larry Shaffer
larrys at dakotacarto.com
Sat Dec 3 17:34:44 PST 2016
Hi Nyall,
(reposting, because I noticed I only replied to you directly before)
On Tue, Nov 29, 2016 at 4:50 PM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On 30 November 2016 at 04:25, Larry Shaffer <larrys at dakotacarto.com>
> wrote:
> > Hi Phil,
> > Does your endpoint prompt an HTTP Basic username/password dialog when
> > connecting to it via a Web browser? If not, then your server may not be
> > sending the correct challenge:
> > https://www.w3.org/Protocols/HTTP/1.0/spec.html#BasicAA
> Larry,
> Is the authentication system supported by the OGR provider? I couldn't
> see anywhere in the provider itself where this is handled.
Indeed, it is not. I think to support that we would need to incorporate the
auth selector dialog into all layer property dialogs, as well as any access
point or API call to GDAL/OGR data. There is no 'connection configuration'
dialog like there is with OWS and Postgres.
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
> Nyall
> > Regards,
> > Larry Shaffer
> > Dakota Cartography
> > On Mon, Nov 28, 2016 at 4:51 PM, Phil (The Geek) Wyatt
> > <phil at wyatt-family.com> wrote:
> >> Hi Folks,
> >> Is there anyone out there that can assist with a QGIS authentication
> >> issue? I am trying to get basic authentication working but it seems to
> be
> >> failing all the time. If someone has used authentication recently I can
> >> supply the site details for testing.
> >> Cheers - Phil
> >> Kiva Lender, Thin Green Line Supporter, Volunteer Mapper (GISMO) - Red
> >> Cross, Wildcare Volunteer
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161203/45ed4aa7/attachment.html>
