[Qgis-user] Grass7 problem on Macos Sierra
    William Kyngesburye
    woklist at kyngchaos.com
    Tue Dec 13 14:29:01 PST 2016
The GRASS provider/plugin are separate from the Processing plugin use of GRASS.  They can run off the same or different installations of GRASS.  Processing runs GRASS tools to process data in any format.  The plugin/provider allows QGIS to view GRASS data and also run GRASS tools on GRASS data.
The plugin is configured from the Plugins-GRASS menu.  The default is compiled into GRASS.  Copy the path from the Processing options and paste it into the GRASS plugin options.
> On Dec 13, 2016, at 9:58 AM, chris marx <chrismarx at gmail.com> wrote:
> Hi,
> I did a clean install of QGIS 2.18 from kyngchaos, and when starting QGIS I get:
> GRASS was not found in '/Users/Shared/unix/grass-qgis-mtlion/grass-7.0.4' (GISBASE), provider and plugin will not work.
> I checked the Processing -> Options -> Providers, and GRASS is pointed at the QGIS/Contents/etc, no where does it have anything pointing at the above location. Any way to fix this?
> Thanks!
> Chris-
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings.  And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
