[Qgis-user] Connecting QGIS to an Android GPS
    Fernando M. Roxo da Motta
    petro at roxo.org
    Mon Dec 26 05:41:39 PST 2016
On Mon, 26 Dec 2016 09:35:12 +0000, Pedro Venâncio
<pedrongvenancio at gmail.com> wrote:
> Hi Paolo,
=========================8<-----------------------------
> So, you do:
> $ sudo rfcomm bind 0 xx:xx:xx:xx:xx:xx 2
> and you will get the /dev/rfcomm0.
  Then you do:
$ ls -l /dev/rfcomm0
crw-rw---- 1 root dialout 216, 0 Dez 26 11:30 /dev/rfcomm0
  Make sure that your user is in the resource group, 'dialout' in this
case:
$ groups
roxo adm dialout cdrom floppy sudo audio dip video plugdev netdev fuse
lpadmin scanner sambashare vboxusers libvirtd gpu wireshark
  If you are not, insert your user there.  You can do it using the
administration tools or edit '/etc/groups' and insert your user there:
$ grep dialout /etc/group
dialout:x:20:roxo
  If you have to insert your user in "dialout", or whatever group it was
created under (never insert your user in root group!!), you will need to
logout and logon again, no restart needed.
> Then run QGIS with root, and connect GPS to /dev/rfcomm0.
  If you follow the steps above, fire QGis with your regular user and
> It is working fine here.
  Ditto.
  Best regards.
  Roxo
P.S.  Every time you have to run an end user application as root, look
for the resource demanding this authority and thy to give it to a
generic non authoritative group.   Insert your user in that group and,
finally, try to use the resource with your user.
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
Except where explicitly stated I speak on my own behalf.|  VI !!
      ( Usuário Linux registrado #39505 )               | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
