[Qgis-user] DWG import
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sat Dec 31 09:47:15 PST 2016
Hi Randal,
I do not use the DWG import tool so there may be a switch or an option  that I do not know of.  I generally export from AutoCAD Map3D with to option to export the z to a column.  The reality is that most AutoCAD drawing (cities plans, architectural drawings)  are still exclusively done in 2D and z is very often a simple texte value with a point symbole.  That may be your case... When you export that, the problem is that the z value point is a label and will systematically be beside the true measurement. You could fix that with some vector manipulations...
Good luck
Nicolas
> Le 31 déc. 2016 à 09:25, Randal Hale [via OSGeo.org] <ml-node+s1560n5301684h65 at n6.nabble.com> a écrit :
> I've been testing the DWG Import - one question. I imported a 3D DWG
> file and all the data data is imported (yay) but there isn't a elevation
> attached anywhere. Is it hidden somewhere or not imported? I really
> think I'm missing a step - possibly.
> Randy
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 [hidden email]
> twitter:rjhale
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/DWG-import-tp5301684.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/DWG-import-tp5301684p5301692.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161231/7b584ad5/attachment.html>
