[Qgis-user] Geophysical Processing
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Tue Feb  2 19:38:41 PST 2016
I have no real idea of what you are doing but I think you will need filters to go from a total magnetic intensity image to a 1VD image.  Try to figure out what these filters are and then Google the filter type with QGIS, Saga or Grass.  Chances are that Saga or Grass have what you need and then you can access them using the qgis processing toolbox plugin.  I wonder if the QGIS semi-automatic classification plugin has that?  Once you have the 1VD image, the hillshade will likely help you enhance the anomalies.
Limited help but better than nothing...
Cheers!
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Feb 2, 2016 9:27 PM, "Grant Boxer [via OSGeo.org]" <ml-node+s1560n5248592h13 at n6.nabble.com> wrote:
	I have a total magnetic intensity image and would like to create a first vertical derivative of the image. I have found the hillshade, slope and aspect operations and wondered what is the best to use as 1VD process?   Grant Boxer Consultant Geologist (FAIG R.P. Geo) Perth, Western Australia   _______________________________________________
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Geophysical-Processing-tp5248592.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geophysical-Processing-tp5248592p5248594.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160202/a45198f5/attachment.html>
