[Qgis-user] New Shapefile Features Fail to Save
Springfield Harrison
stellargps at gmail.com
Wed Feb 3 08:52:09 PST 2016
If I understand the technical aspects correctly (marking shapes with a *
rather than actually deleting them), the problem seems to be departing from
the shapefile "standard".
One of QGIS's strengths should be interoperability rather than inventing
one off, wierd standards to frustrate compatibility.
I don't think this is behind the failure to save problem but is concerning
nonetheless . . . .
Cheers . . . . . Spring
Samsung Tab 4
On Feb 3, 2016 12:40 AM, "Uwe Fischer" <gisfisch at t-online.de> wrote:
> Spring,
> it seems to me like there are various errors in editing shapefiles in QGIS
> 2.10 and 2.12. Some weeks ago, I reported an error that does not allow for
> proper feature deleting. The shapes I deleted were gone in QGIS, but they
> were still present in ArcMap.
> Matthias Kuhn wrote in this context:
> Hi
> I just received a confirmation that Marco is working on a fix for this
> issue and targets the 2.14 release.
> GDAL 2.0 would still be nice to also have the geometry issue fixed :)
> Best regards
> Matthias Kuhn
> If it turns out that your problems come from the same origin, maybe it’s
> time now to disable shapefile editing in QGIS until those problems are
> solved.
> Maybe someone more competent than me can give information to the list on
> the troubleshooting status? QGIS is such an outstanding piece of software,
> we’d love to see that errors disappear!
> Mit freundlichen Grüßen,
> Uwe Fischer
> *Von:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *Im Auftrag
> von *Springfield Harrison
> *Gesendet:* Mittwoch, 3. Februar 2016 07:30
> *An:* Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
> *Cc:* qgis-user <qgis-user at lists.osgeo.org>
> *Betreff:* Re: [Qgis-user] New Shapefile Features Fail to Save
> Thanks for those ideas. I can check off most of those items except
> upgrading. This is new development so likely computer based? Rather than
> QGIS.
> I'll look at the bug reports; this is a pretty serious error. Thank you
> Samsung Tab 4
> On Feb 2, 2016 7:15 PM, "Nicolas Cadieux" <nicolas.cadieux at archeotec.ca>
> wrote:
> Hi,
> I have done this in the past without errors in QGIS. I would upgrade to
> the latest version. Then to figure out where the problem is, I would:
> Make sure that both layer are polygon layers (and not lines and polygons),
> that both have the same CRS (along with the project CRS), that both have
> the same fields and that the "receiving layer" is in editing mode, and
> saved subsequently. I would limited the amount of open files and open
> plugins.
> Try copying polygons from a newly created file to an empty newly created
> layer in QGIS and not a shapefile that was previously manipulated in other
> softwares. All this could help you find the source of the problem.
> I would also look at the bug reports to see if it is an issue for that
> version.
> Hope this helps.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112 Fax: 514.381.4995
> www.archeotec.ca
> On Feb 2, 2016 8:46 PM, "Springfield Harrison [via OSGeo.org] " <[hidden
> email] <http://user/SendEmail.jtp?type=node&node=5248593&i=0>> wrote:
> Hello Group,
> Am using QGIS 2.10.1 and have done so without significant problems
> for many months. I am attempting to create simple polygons in a shapefile
> by direct vertex entry or copying polygons from another shapefile layer and
> pasting them into the active layer.
> In almost every case, these features disappear. There is an
> entity entry in the attribute table but there are no polygons created. In
> one case a polygon was created but it was not the shape that I digitized;
> no more polygons could be created although the process for doing so appears
> to be working. No error messages were created. The CRS for the project
> and the shapefile are the same.
> The shapefile can be opened in another GIS but has no content.
> Here are some product details: QGIS version 2.10.1-Pisa QGIS
> code revision d20c5b7 <https://github.com/qgis/QGIS/commit/d20c5b7>
> Thanks very much for any help you can render, Cheers . . . . . . .
> . Springfield Harrison
> Qgis-user mailing list
> <a
> href="/user/SendEmail.jtp?type=node&node=5248589&i=0">[hidden
> email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> *If you reply to this email, your message will be added to the discussion
> below:*
> http://osgeo-org.1560.x6.nabble.com/FW-QGIS-crashes-when-using-mouse-wheel-to-zoom-in-and-out-of-WMTS-services-tp5248434p5248589.html
> To start a new topic under Quantum GIS - User, email
> ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg==">click
> here.
> <a href="
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>"
> style="font:9px serif">NAML
> View this message in context: Re: New Shapefile Features Fail to Save
> <http://osgeo-org.1560.x6.nabble.com/FW-QGIS-crashes-when-using-mouse-wheel-to-zoom-in-and-out-of-WMTS-services-tp5248434p5248593.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160203/fb8136c7/attachment.html>
