[Qgis-user] Problem w/ Processing Plugin in Mac
Alexander Bruy alexander.bruy at gmail.com
Wed Feb 3 11:17:41 PST 2016
Hi Michael,
try to remove Processing plugin from your user directory,
e.g. /Users/evan/.qgis2/python/plugins/processing
2016-02-03 21:02 GMT+02:00 Michael Treglia <mtreglia at gmail.com>:
> Hi All,
> I have a student trying to work with QGIS on a Mac and is having trouble
> starting the Processing Plugin; I'm primarily Windows & Ubuntu user and
> thought some Mac users on the list might have some trouble-shooting tips I
> can recommend. (It might be something simple - I just haven't encountered
> this issue before, and a lot of the options I see on StackExchange are
> homebrew focused).
> The student is on a fairly recent version of OS 10, and said he installed
> QGIS via the downloads (w/ dependencies) available from KyngChaos.
> The student first started with 2.12.1-1, and when trying to make sure the
> processing plugin was activated/installed, got this error:
> Couldn't load plugin 'processing'
> ImportError: cannot import name spatialite_utils
> I can send the entire traceback if needed, but this is where it seems to
> have gotten hung up:
>   File "/Users/evan/.qgis2/python/plugins/processing/tools/vector.py", line
> 20, in
>     from processing.algs.qgis import spatialite_utils
> They then tried QGIS 2.8.4-1 (also from KyngChaos), with Processing throwing
> the result given at the end of this e-mail. I will be meeting with the
> student later today to try a couple of things, but any suggestions of what
> might be going on or how to deal with this are welcome. I think for the
> 2.8.4, might just need to remove the .qgis folder and start over, but it
> would be great to solve the issue in 2.12 also.
> Thanks!
> Mike
> Couldn't load plugin 'processing' from
> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
> '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
> '/Users/evan/.qgis2/python', '/Users/evan/.qgis2/python/plugins',
> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
> '/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7',
> '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7/site-packages',
> '/Library/Python/2.7/site-packages/numpy-override',
> '/Library/Python/2.7/site-packages/matplotlib-override',
> '/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
> '/Library/Python/2.7/site-packages', '/Users/evan/.qgis2//python',
> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
> Traceback (most recent call last):
>   File
> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
> line 196, in loadPlugin
>     __import__(packageName)
>   File
> line 478, in _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>   File "/Users/evan/.qgis2/python/plugins/processing/__init__.py", line 29,
> in
>     from processing.tools.general import *
>   File
>   File "/Users/evan/.qgis2/python/plugins/processing/tools/general.py", line
> 28, in
>     from processing.core.Processing import Processing
>   File
>   File
> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
> line 41, in
>     from processing.gui.AlgorithmClassification import AlgorithmDecorator
> ImportError: cannot import name AlgorithmDecorator
> Python version:
> 2.7.10 (default, Oct 23 2015, 18:05:06)
> [GCC 4.2.1 Compatible Apple LLVM 7.0.0 (clang-700.0.59.5)]
> QGIS version:
> 2.8.4-Wien Wien, exported
> Python path:
> u'/Users/evan/.qgis2/python', u'/Users/evan/.qgis2/python/plugins',
> '/Library/Python/2.7/site-packages', u'/Users/evan/.qgis2//python',
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Alexander Bruy
