[Qgis-user] QGIS Server sending UPDATE... WHERE NULL to postgis in a WFS layer
jaitor
sigeo.agmartin at getxo.eus
Thu Feb 4 04:20:05 PST 2016
I am running a Windows Server 2012 server.
PostgreSQL 9.3.5, 64-bit
POSTGIS 2.1.3
QGIS Server 2.6.1-2
QGIS Desktop 2.8.3 and 2.12
I am using a Microsoft Surface Pro 4 tablet using QGIS Desktop 2.12 to edit
some layers stored in the Postgresql database. The layers in the tablet are
WFS layers served by QGIS Server.
When I toogle editing after inserting some data in the layer to force the
data to be sent and stored in the server sometimes the update is not being
done in the Database.
I can see that the POST http request arrives to the server ok, but sometimes
I can't see a commit (update) in the database and some other times it works
ok and does the commit.
In QGIS Server's logs I can see (I updated 3 features' data in QGIS
Desktop):
//QGIS SERVER RECEIVED HTTP POST FROM QGIS DESKTOP
[4852][11:11:19] ********************new request***************
[4852][11:11:19] remote ip: 192.168.144.20
[4852][11:11:19] CONTENT_TYPE: text/xml
[4852][11:11:19] HTTP_USER_AGENT: Mozilla/5.0 QGIS/2.8.2-Wien
[4852][11:11:19] MAP:D:\OSGeo4W\apps\qgis\bin\alumbrado\alumbrado.qgs
[4852][11:11:19] REQUEST:Transaction
[4852][11:11:19] REQUEST_BODY:<Transaction
xmlns="http://www.opengis.net/wfs"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0"
service="WFS" xsi:schemaLocation="http://www.qgis.org/gml
http://eudala2.getxo.net/qgis/qgis_mapserv.fcgi.exe?map=D:\OSGeo4W\apps\qgis\bin\alumbrado\alumbrado.qgs&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=getxo_alumbrado_arquetas_registros_cajas&SRSNAME=EPSG:23030"
xmlns:gml="http://www.opengis.net/gml"><Update
typeName="getxo_alumbrado_arquetas_registros_cajas"><Property
xmlns="http://www.opengis.net/wfs"><Name
xmlns="http://www.opengis.net/wfs">id_modelo</Name><Value
xmlns="http://www.opengis.net/wfs">0</Value></Property><Property
xmlns="http://www.opengis.net/wfs">alumbrado</Name><Value
xmlns="http://www.opengis.net/wfs">t</Value></Property><Filter
xmlns="http://www.opengis.net/ogc"><FeatureId
fid="getxo_alumbrado_arquetas_registros_cajas.3"/></Filter></Update><Update
fid="getxo_alumbrado_arquetas_registros_cajas.4"/></Filter></Update><Update
xmlns="http://www.opengis.net/wfs">tipo</Name><Value
xmlns="http://www.opengis.net/wfs">A</Value></Property><Property
xmlns="http://www.opengis.net/wfs">tipo_tapa</Name><Value
xmlns="http://www.opengis.net/wfs">B</Value></Property><Property
xmlns="http://www.opengis.net/wfs">estado</Name><Value
xmlns="http://www.opengis.net/wfs">D</Value></Property><Property
xmlns="http://www.opengis.net/wfs">p_tierra_tipo_electrodo_tierra</Name><Value
xmlns="http://www.opengis.net/wfs">O</Value></Property><Property
xmlns="http://www.opengis.net/wfs">p_tierra_tipo_union_electrodo_tierra</Name><Value
xmlns="http://www.opengis.net/wfs">N</Value></Property><Property
xmlns="http://www.opengis.net/wfs">p_tierra_estado_union_tierra</Name><Value
xmlns="http://www.opengis.net/wfs">tipo_intervencion</Name><Value
xmlns="http://www.opengis.net/wfs">OTR</Value></Property><Property
xmlns="http://www.opengis.net/wfs">m_codcalle</Name><Value
xmlns="http://www.opengis.net/wfs">20</Value></Property><Property
fid="getxo_alumbrado_arquetas_registros_cajas.5"/></Filter></Update></Transaction>
[4852][11:11:19] SERVICE:WFS
[4852][11:11:19] SRSNAME:EPSG:23030
[4852][11:11:19] VERSION:1.0.0
[4852][11:11:22] Request finished in 2977 ms
Ok, when I look into PostgreSQL logs I can see that the update has a WHERE
NULL clause, which updates nothing..
//POSTGRESQL UPDATE QUERIES
2016-01-29 11:11:22 CET LOG: 00000: sentencia: UPDATE
"public"."getxo_alumbrado_arquetas_registros_cajas" SET
"id_modelo"=0,"alumbrado"='t' WHERE NULL
2016-01-29 11:11:22 CET UBICACIÓN: exec_simple_query,
src\backend\tcop\postgres.c:890
"tipo"='A',"tipo_tapa"='B',"estado"='D',"p_tierra_tipo_electrodo_tierra"='O',"p_tierra_tipo_union_electrodo_tierra"='N',"p_tierra_estado_union_tierra"='D',"tipo_intervencion"='OTR',"m_codcalle"='20',"id_modelo"=0,"alumbrado"='t'
WHERE NULL
I can see in the POST data that QGIS Server knows which feature needs to be
updated using de internal "fid" number. My layer, on the other hand, has
"id" field as primary key. Somewhere when it does the mapping from QGIS
internal fid to my layer's id it's getting lost and adds WHERE null to the
query instead of adding where id=1510.
The funny thing is that they have been working for 40 days and hey only got
this problem once, but since last week they have had this problem every
day...Since then sometimes works and sometimes not. I resend the POST http
request from client ysing Fiddles proxy and the same HTTP post sometimes
works and other times don't.
I tested it in QGIS Desktop 2.8, 2.10 and 2.12 and happens in all of them
(QGIS Server is 2.6.1 I think). I also tested it with different layers with
same result.
I don't know if there is a bug or there is some kind of config to the layer
I am not doing properly in server...
Regards,
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-Server-sending-UPDATE-WHERE-NULL-to-postgis-in-a-WFS-layer-tp5248880.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
