[Qgis-user] [GRASS-user] QGIS - GRASS Plugin not loading
César Augusto Ramírez Franco
caesarivs at gmail.com
Thu Feb 4 12:59:12 PST 2016
Hi Jürgen,
Thanks for your reply, however, I'd like to stay away from non-stable
releases, and sadly, I tried using the QGIS-ubuntugis-ltr repo but the
plugin doesn't even install
2016-02-04 12:50 GMT-05:00 Jürgen E. <jef at norbit.de>:
> Hi César,
> On Thu, 04. Feb 2016 at 11:50:44 -0500, César Augusto Ramírez Franco wrote:
> > GRASS init error: Problem in GRASS initialization, GRASS provider and
> > plugin will not work : Module built against version $Revision: 64733 $
> but
> > trying to use version $Revision: 67364 $. You need to rebuild GRASS GIS
> or
> > untangle multiple installations.
> QGIS was built against a earlier version of GRASS. It's only built after
> release but not whenever dependencies change.
> Try the our nightlies. Those are not built when dependencies change
> either,
> but whenever there was a new commit on the branch. So there is a chance
> that a
> QGIS update triggered a rebuild after GRASS was updated.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
*César Augusto Ramírez Franco*
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias - Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 300 459 6085
http://labscn-unalmed.github.io/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160204/bbf31c28/attachment.html>
