[Qgis-user] [GRASS-user] QGIS - GRASS Plugin not loading
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Fri Feb 5 03:43:07 PST 2016
Hi Bernd,
Depends how you define "stable".
The nightlies for 2.12 are only receiving bugfixes, so they can be even more "stable" than the current point release. However, also fixes can in principle introduce new bugs...
That the GRASS plugin does not install in 2.8 is simply due to the fact that it first got introduced in 2.12 (see: http://qgis.org/en/site/forusers/visualchangelog212/#plugins)...
Anyway,I would very much like to see the GRASS integration in QGIS becoming a bit more smooth. There have been several post regarding problems with the installation of the plugin lately.
Since the GRASS GIS 7.0.3 just was released: would it be possible to build new packages for the different platforms? Currently it is quite cumbersome, esp. on windows where I have to install two QGIS versions (qgis and qgis-rel-dev, since "qgis" is the dependency of the plugin and I cannot install only "qgis-rel-dev" alone).
In future, avoiding to build the plugin against GRASS release candidates (like Martin Landa suggested for Windows) could be a solution. However, the drawback might be that, people might have to decide whether they want to test the GRASS RC or keep the QGIS plugin dependencies. Would it be an option to have parallel builds / packages for the stable GRASS 7 and the RC (like qgis, qgis-rel-dev and qgis-dev)?
Cheers
Stefan
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Bernd Vogelgesang
Sent: 5. februar 2016 11:46
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] [GRASS-user] QGIS - GRASS Plugin not loading
Am 05.02.2016, 02:28 Uhr, schrieb Jürgen E. Fischer <jef at norbit.de>:
> On Thu, 04. Feb 2016 at 15:59:12 -0500, César Augusto Ramírez Franco
> wrote:
>> Thanks for your reply, however, I'd like to stay away from non-stable
>> releases, and sadly, I tried using the QGIS-ubuntugis-ltr repo but
>> the plugin doesn't even install
> I meant the nightlies of 2.12 (or 2.8). See
> http://qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu
Am confused.
He says that he prefers not to use non-stable versions, and you propose the nightlies.
Are the nightlies for 2.12 as stable as the "normal" ubuntugis stuff? If so, why should I bother than using the normal ubuntugis version?
Cheers
Bernd
> Jürgen
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
