[Qgis-user] QGIS - GRASS Plugin not loading
knussear
knussear at mac.com
Fri Feb 5 05:40:05 PST 2016
I'm having the same problem with the regular release. I switched to nightly
ubuntu as recommended above, removed and reinstalled qgis, python-qgis and
qgis-plugin-grass
When I run 2.12.3 there is no grass plugin present under the plugin manager
at all... Yet it would appear that the install went OK? Can anyone help?
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
qgis-plugin-grass
0 upgraded, 1 newly installed, 0 to remove and 16 not upgraded.
Need to get 0 B/4,013 kB of archives.
After this operation, 14.0 MB of additional disk space will be used.
Selecting previously unselected package qgis-plugin-grass.
(Reading database ... 176411 files and directories currently installed.)
Preparing to unpack
.../qgis-plugin-grass_1%3a2.12.3+git20160124+02885d5+20trusty-ubuntugis_amd64.deb
Adding 'diversion of /usr/bin/qgis to /usr/bin/qgis.bin by
qgis-plugin-grass'
Adding 'diversion of /usr/bin/qbrowser to /usr/bin/qbrowser.bin by
qgis-plugin-grass'
Unpacking qgis-plugin-grass
(1:2.12.3+git20160124+02885d5+20trusty-ubuntugis) ...
Setting up qgis-plugin-grass
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-GRASS-Plugin-not-loading-tp5248938p5249104.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
