[Qgis-user] QGIS DB Manager geometry columns issue with PostGIS	2.0
    Thomas Endres
    endres.thomas at gmail.com
    Fri Feb  5 08:24:56 PST 2016
I found the information from this link helpful:
http://gis.stackexchange.com/questions/157541/postgresql-trouble-editing-points-lines-polygons-in-qgis
Altering the geometry type was what fixed things for me.
ALTER TABLE planet_osm_polygon
    ALTER COLUMN way TYPE geometry(MultiPolygon,3857) USING ST_Multi(way);
HTH,
-tom
On Fri, Feb 5, 2016 at 10:11 AM, Chris Buckmaster <
chris.buckmaster at runnymede.gov.uk> wrote:
> Hi Andreas
> Yes it does exist in the geometry column view but the type is listed as
> GEOMETRY.
> This table is being created from a non-spatial SQL Server table, and we
> use a vertex creator transformer in FME to create the spatial table – we
> cannot seem to explicitly specify the geometry that the spatial table
> should be as it is not a spatial layer when imported?
> Chris
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Andreas Neumann
> *Sent:* 05 February 2016 12:43
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] QGIS DB Manager geometry columns issue with
> PostGIS 2.0
> Hi Chris,
> That's true - starting from Postgis 2.0, geometry_columns is a view in the
> public schema.
> Did you check if that view exists and if the view contains an entry for
> your spatial table?
> Also make sure, when importing from FME, that you restrict your geometry
> type to either POINT, POLYGON, LINESTRING, COMPOUNDCURVE or the MULTI
> versions. QGIS likes a single geometry type per table, while Postgis would
> permit to store mixed geometry types in the same geometry column.
> Maybe you did not specify this geometry type restriction when importing
> your data with FME.
> Andreas
> On 05.02.2016 13:33, Chris Buckmaster wrote:
> Hi
> I have been using FME to load some data into PostGIS and view it in QGIS
> 2.12.3.
> I am finding that when accessing the data in DB Manager, I get a warning
> that says ‘There is no entry in geometry_columns!’.
> On asking another user they mentioned that the geometry columns table was
> removed in PostGIS 2.0, so my question is, is this a known issue / bug
> within QGIS, or is it the way in which I am storing my data? Just wondering
> if this will be looked at in future QGIS versions.
> Thanks, Chris
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160205/cfaf1dfa/attachment.html>
