[Qgis-user] Adding Points by Coordinates
Neumann, Andreas
a.neumann at carto.net
Sun Feb 7 23:18:02 PST 2016
Hi Grant,
As often - there are several ways to achieve to create/edit features
with exact coordinates.
* The add as CSV file way that others already mentioned
* The NumericalDigitize plugin
* The CAD-Tools - allow you to construct features on exact coordinates
and distances/angles (not sure exactly with which version whis was
introduced - maybe 2.8 or 2.10)
* The Plain Geometry Editor plugin (you need to first add an approximate
point and then set the exact coordinates)
* The vertex editor panel (starting from 2.12 --> requires you to first
set an approximate point and then edit the values to the exact
coordinates in a second step - you need the node tool to see the vertex
editor panel)
The first two options are probably easiest to use - but the three other
may be useful to work with exact coordinates in existing layers where
you need to modify specific nodes of polygon or line features. For a
point geometry they may be too complicated to use.
Andreas
On 2016-02-08 02:39, Grant Boxer wrote:
> Is there an option in QGIS to add a point by entering its co-ordinates. For example I have a drill hole position in UTM coordinates and I want to create a new layer for this drill hole.
> Thanks Grant
> Grant Boxer
> Consultant Geologist (_FAIG R.P. Geo_)
> Perth, Western Australia
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160208/a052d84c/attachment.html>
