[Qgis-user] Create rectangle with minLat,maxLat,minLon,maxLon
    gam17 at riseup.net
    gam17 at riseup.net
    Mon Feb  8 03:00:17 PST 2016
    you can use a plugin called QAD (https://github.com/geosim/QAD).
code repository is here:
download zip from here:
https://github.com/geosim/QAD/archive/master.zip then unzip in
<home>/.qgis2/python/plugins then remove the "-master" suffix
(otherwise you'll have python invalid syntax during loading plugin
module) and restart QGIS.
The current coordinate system must be a projected system if you want QAD
commands to work.
You can draw a rectangle specifing the coordinates in any coordinate
system (look at the QAD documentation,
section "Coordinate specified in a coordinate reference system different
from the current one").
Type "rectangle" command (english version) in the text window or use
toolbar or menu (vector->QAD).
>> 	Hi,
>> I have a very basic question, but could not find an answer. How do I
>> create a rectangle based on minLat, minLon, maxLat, maxLon? I have a
>> table with 100,000+ rectangle bounds.
>> 		If you reply to this email, your message will be added to the
>> discussion below:
>> 		http://osgeo-org.1560.x6.nabble.com/Create-rectangle-with-minLat-maxLat-minLon-maxLon-tp5248969.html
>> 		To start a new topic under Quantum GIS - User, email
>> ml-node+s1560n4125267h38@n6.nabble.com
>> 		To unsubscribe from Quantum GIS - User, click here .
>> 		NAML
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Create-rectangle-with-minLat-maxLat-minLon-maxLon-tp5248969p5248971.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
