[Qgis-user] Possibility to disable Vertex Editor Panel?
JoshS
josh-talk at hotmail.com
Mon Feb 8 08:22:03 PST 2016
Hello,
in QGIS 2.12 (Windows 64bit) if you select the Node Tool and click on a Node
in an editable vector layer a dialog called "Vertex Editor" shows up. This
tool can be very useful. However most of the time I don't need it. Is there
a possibility to disable the Vertex Editor Panel so it doesn't show up
automatically? For me this is important because I am using a Plugin that has
a special UI and the Vertex Editor Panel just doesn't fit in.
Thank you very much!
Josh
View this message in context: http://osgeo-org.1560.x6.nabble.com/Possibility-to-disable-Vertex-Editor-Panel-tp5249530.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
