[Qgis-user] [QGis 2.10]Error while saving shape file
Lester Anderson
arctica1963 at gmail.com
Mon Feb 8 08:55:39 PST 2016
I have not come across this error (so far) when working with
shapefiles, and we often exchange shapefiles generated in QGIS with
ArcGis people. Is it a problem with data with lots of attributes? Will
need to test with 2.10 and 2.12.
On 8 February 2016 at 15:54, Pierre Muckensturm <pierre at georezo.net> wrote:
> I''ve created the file in QGis, edited it in QGis, never used esri with this
> file. Id is the default field (i'm assuming this is the object id) QGis
> create when you create a shp.
> Le 8 févr. 2016 16:02, "Mats Elfström" <mats.elfstrom at gmail.com> a écrit :
>> Hi Pierre!
>> Your Id field, which you updated, is it the FID or Object ID field in the
>> shapefile?
>> If so, you have broken the shape file by updating it outside of ESRI
>> applications.
>> The FID is the internal key between the geometry and the dbase attribute
>> table, and it should never be altered or trusted, or used for any purpose.
>> Actually, QGis ought to hide that field by default.
>> Regards, Mats.E
>> 2016-02-08 14:34 GMT+01:00 Pierre Muckensturm <pierre at georezo.net>:
>>> Hi,
>>> I use a QGis 2.10 version, X64 on Windows installed with Osgeo4W.
>>> I'll try to explain the bug.
>>> I work on a map, with a shape file of polygons. They are not really
>>> complex, nor numerous (25). I got id, DOSSIER, NOM_OPERAT,
>>> PRIORITE, COMMENTA, DATE_MAJ, SOURCE, LIBELLE_X, LIBELLE_Y
>>> fields and SURF_HA which is a virtual field.
>>> Friday, it took me 5 min to save the file each time I modify a vertex.
>>> Today, I update my id field with the expression "$id". Then, my shape
>>> file looks like a totally mess (look at the imgur album :
>>> http://imgur.com/a/noSM2). The LIBELLE_X, LIBELLE_Y fields have disappeard,
>>> the DOSSIER field which used to be null is now partially fulled, the
>>> NOM_OPERAT are truncated, fulled in a completelly non-sense manner. As for
>>> PRIORITE, DATE_MAJ.
>>> Conclusion, 2 days of work in a trash. I'm quite pissed off, according
>>> with the fact that I'm trying to convince my superior we shall use QGis.
>>> So, what happened ? How could this happen ? Sorry but I don't have the
>>> genuine files, and the data are quite sensitive.
>>> PLM
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Mats Elfström, Väpplingvägen 21, SE-227 38 LUND, Sweden
>> tel: +46 46 145959 / mob: +46 70 595 39 35
>> alt e-mail: mats.elfstrom at giskraft.com
