[Qgis-user] Repairing Topology Errors
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Feb 8 23:44:17 PST 2016
when looking at topology errors I can imagine three types
1) borders are not identical, i.e. you missed one vertex during digitizing
2) overlaps
3) gaps
ad 1) in my experience it is easy to miss a vertex when digitizing along
an existing edge, the auto-trace plugin may help in this respect and
also "avoid intersections" (although you seem to have had problems with
it). Snapping must be activated, of course. You cannot snap without it
because you never hit the exact same point twice.
So for your edit layer you should snap to vertex with a reasonable
snapping distance and "avoid intersections". Thus you should be set to
not miss any vertices.
fix: only manually AFAIK
2) have "avoid intersections" active
fix: I use GRASS with its topological data model to identify all
averlaps and use Processing's "eliminate sliver polygons" to get rid of them
3) no way to avoid them because IMHO they could be intended
fix: same as 2)
Bernhard
Am 08.02.2016 um 20:26 schrieb Springfield Harrison:
> Hello Group,
> I have been manually creating a few simple polygons, always intending to
> have no gaps, slivers or overlaps. To do this I use snapping and
> occasionally the Autotrace feature.
> However, when I run the topology checker, it often flags a variety of
> errors although I am careful to create polygons by only snapping to
> existing vertices of adjacent polygons. It does a great job of finding
> the errors, but I can find no instructions on methodology for repairing
> them.
> Any suggesting on repairing topology errors easily?
> Thank you, Cheers . . . . . . . . Spring Harrison
> At 03-02-2016 07:51 Wednesday, Carlos Cerdán wrote:
>> Hi Springfield:
>> I've had similar trouble some time ago, as a QGIS beginner user.
>> Previous given advices are for not too-beginner users, but I think my
>> experience can be useful for the list (or even for you?):
>> That time my error was my Snapping options: I had selected two or
>> three layers and it was selected the "avoid intersections" option,
>> then, when I added new digitized polygons, they were splitted or
>> deleted (as you tell) because new polygons were intersecting marked
>> layers in snapping options. It fixed when new digitizing shape was the
>> one marked (of course to avoid intersections between her elements) .
>> Yes it was something simple, my foul. Is it not same trouble?. If so,
>> Check it in "Configuration --> Snapping options --> Change the
>> Self-assembling mode to "advanced" and be sure that "avoid
>> intersections" is marked in your target layer only.
>> Cheers,
>> Carlos Cerdán
>> 2016-02-02 20:57 GMT-05:00 Springfield Harrison <stellargps at gmail.com
>> <mailto:stellargps at gmail.com> >:
>> Hello Group,
>> Â Â Â Â Â Â Â Â Am using QGIS 2.10.1 and have done so without
>> significant problems for many months. I am attempting to create
>> simple polygons in a shapefile by direct vertex entry or copying
>> polygons from another shapefile layer and pasting them into the
>> active layer.
>> Â Â Â Â Â Â Â Â In almost every case, these features disappear.Â
>> There is an entity entry in the attribute table but there are no
>> polygons created. In one case a polygon was created but it was
>> not the shape that I digitized; no more polygons could be created
>> although the process for doing so appears to be working. No error
>> messages were created. The CRS for the project and the shapefile
>> are the same.
>> Â Â Â Â Â Â Â Â The shapefile can be opened in another GIS but has
>> no content.
>> Â Â Â Â Â Â Â Â
>> Â Â Â Â Â Â Â Â Here are some product details:Â QGIS versionÂ
>> 2.10.1-Pisa QGIS code revision d20c5b7
>> <https://github.com/qgis/QGIS/commit/d20c5b7>
>> Â Â Â Â Â Â Â Â Thanks very much for any help you can render,
>> Cheers . . . . . . . . Springfield Harrison
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> _______________________________________________ Qgis-user mailing list
>> Qgis-user at lists.osgeo.org List info:
>> http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe:
> __________ Information from ESET Mail Security, version of virus
> signature database 12996 (20160208) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 12999 (20160209) __________
http://www.eset.com
