[Qgis-user] Correct the attribute table automatically
Neumann, Andreas a.neumann at carto.net
Wed Feb 10 01:27:33 PST 2016
The question is if you need a "physical field" (stored in your data
provider) or if a virtual field is good enough. If you don't need
physical storage in the table, I suggest you add a virtual field with an
expression to calculate the area an potentially also round/format the
result.
You can create virtual fields in the field calculator and upate the
expression/calculcation from the fields tab in the layer properties.
Andreas
On 2016-02-10 10:18, Josefine Petrenz wrote:
> hej hej,
> at first, I would like to apologize for my english.
> I have a shape-file with several areas. In my attribut table, each area has an information about the area size. Step by step the areas become bigger or smaller. Every time, when this happened, i have to recalculate the area size.  is there a way, that the area size correct automatically in the attribute table, when i change the area?
> thanks in advance josi
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160210/c4870806/attachment.html>
