[Qgis-user] How to change number in all features with field calculator
Joris Hintjens jorishin at gmail.com
Fri Feb 12 11:30:20 PST 2016
there is a plugin to speed that up.
QuickMultiAttributeEdit
greets
Joris
> Op 10 feb. 2016, om 15:08 heeft Philip Pierdomenico <ppierdo at gmail.com> het volgende geschreven:
> Select all the records that have -99999997.  Then open field calculator, check the box for "Only update selected features" and "Update existing field" and enter the expression toint(0).
> Phil
> On Wed, Feb 10, 2016 at 8:13 AM, Willem Korevaar <wereldvak at gmail.com <mailto:wereldvak at gmail.com>> wrote:
> I have a attribution table with multiple rows . I want to replace a number --99999997 to '0'  (=zero) for the whole of the attribute table. I have used the expression - case when   "P_ANT_ARU"  is  -99999997  then '0' else    "P_ANT_ARU"  end -  for every feature but I wonder if there a faster way to use in the field calculator to get rid of -99999997.
> Willem Korevaar
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160212/5b41b88c/attachment.html>
