[Qgis-user] Error installing qgis 2.13 from ubuntugis-nightly/
Gustavo Martinez
gmpuljak at yahoo.com.ar
Sat Feb 13 05:50:28 PST 2016
I've just installed qgis 1:2.13.0+git20160213+7489af8+20trusty-ubuntugis
without problems, but when I started it it gave the following error:
No se pudo cargar PyQGIS. El soporte para Python estará deshabilitado.
Traceback (most recent call last): File "", line 1, in File
"/usr/lib/python2.7/dist-packages/qgis/gui/__init__.py", line 26, in
from qgis._gui import * ImportError:
/usr/lib/python2.7/dist-packages/qgis/_gui.x86_64-linux-gnu.so:
undefined symbol:
_ZN17QgsMapToolCapture9addVertexERK8QgsPointN15QgsPointLocator5MatchE
Versión de Python: 2.7.6 (default, Jun 22 2015, 18:01:27) [GCC 4.8.2]
Versión de QGIS: 2.13.0-Master 'Master', exported Ruta de Python:
['/usr/share/qgis/python', u'/home/gustavo/.qgis2/python',
u'/home/gustavo/.qgis2/python/plugins',
'/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
'/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PILcompat',
'/usr/lib/python2.7/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.7',
'/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
Can I do something?
Thanks for your time.
Gustavo
El 11/02/16 a las 15:20, Gustavo Martinez escribió:
> Hi,
> I've been using qgis 2.13 from http://qgis.org/ubuntugis-nightly/ for
> some time without problems, until now. When I tried to update qgis it
> Preparing to unpack
> .../qgis_1%3a2.13.0+git20160211+169d35f+20trusty-ubuntugis_amd64.deb ...
> Unpacking qgis (1:2.13.0+git20160211+169d35f+20trusty-ubuntugis) ...
> dpkg: error al procesar el archivo
> /var/cache/apt/archives/qgis_1%3a2.13.0+git20160211+169d35f+20trusty-ubuntugis_amd64.deb
> (--unpack):
> intentando sobreescribir `/usr/bin/qgis.bin', que es la versión
> desviada de `/usr/bin/qgis' (paquete qgis-plugin-grass)
> dpkg-deb: error: el subproceso copiado fue terminado por la señal
> (Tubería rota)
> Processing triggers for mime-support (3.54ubuntu1.1) ...
> E: Sub-process /usr/bin/dpkg returned an error code (1)
> I am running it on a linux Mint 17.3 (64 bit) notebook.
> How can I fix it?
> Thanks,
> Gustavo
Gustavo Martínez
Skype: gmpuljak
Linkedin: http://ar.linkedin.com/pub/gustavo-martínez-puljak/38/41/249
“Que la tierra se vaya haciendo camino ante tus pasos,
que el viento sople siempre a tus espaldas,
que el sol brille cálido sobre tu cara,
que la lluvia caiga suavemente sobre tus campos y,
hasta tanto volvamos a encontrarnos,
que Dios te lleve en la palma de su mano.”
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160213/1cd7fbdc/attachment.html>
