[Qgis-user] Custom CRS: from WKT to PROJ.4
Jakob Petersen
pbokaj at gmail.com
Mon Feb 15 08:54:08 PST 2016
Hi Joris, Do you know the PROJ.4 for it? Did not manage to find in on
spatialreference.org. Jakob
On Mon, Feb 15, 2016 at 3:29 PM, Joris Hintjens <jorishin at gmail.com> wrote:
> did you try using the predefined projection "EPSG9001" ?
> Op 15 feb. 2016, om 16:17 heeft Jakob Petersen <pbokaj at gmail.com> het
> volgende geschreven:
> I’m using QGIS to produce a .svg layer to be imported into Adobe
> Illustrator and added to an existing map project. Apparently, a EPSG
> projection was not used and the following WKT parameters have been provided:
> PROJCS["Orthographic, meter (Pakistan)",GEOGCS["WGS
> 84",DATUM["wgs_1984",SPHEROID["WGS
> 1984",6378137,298.257223563],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]],PROJECTION["Orthographic"],PARAMETER["false_easting",0],PARAMETER["false_northing",0],PARAMETER["latitude_of_center",30.292],PARAMETER["longitude_of_center",69.178],UNIT["Meter",1,AUTHORITY["EPSG","9001"]]]
> To write the PROJ.4 for the QGIS customised CRS I have used the parameters
> (+proj +lat_0 +lon_0 +x_0 +y_0) listed in
> http://www.remotesensing.org/geotiff/proj_list/orthographic.html
> The projection comes close, but I wonder if more parameters can be used
> than the ones listed by remotesensing.org?
> Many thanks, Jakob
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Jakob
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160215/b3531c52/attachment.html>
