[Qgis-user] Using PostgreSQL to store Lizmap Web Client accounts..
Nicolas Boisteault boisteault at observatoire-environnement.org
Wed Feb 17 00:49:52 PST 2016
You should ask your question here :
https://github.com/3liz/lizmap-web-client/issues
Nicolas BOISTEAULT
Développeur Web
Observatoire Régional de l'Environnement Poitou-Charentes
Téléport 4 Antarès - BP 50163 - 86962 Futuroscope Chasseneuil Cedex
Tél : 05 49 49 71 18
*Soyez Eco-responsable, n'imprimez que si nécessaire*
Le 12/02/2016 13:42, Rossin Pietro a écrit :
> Hello
> I’m not a Lizmap Web Client Guru but I’m trying to manage it in my
> organization.
> I see version 3 is near to be published and I’m testing the Beta 3 one.
> I am thinking to migrate the user logins and group roles from the
> jauth.db to a PostgreSQL database.
> First of all, is it of any advantage to store these data into a
> postgresql db?
> I figure it would be good as the number of users will rise and
> considering the opportunity to upgrade lizmap wc version frequently,
> as I saw any new version carry lot of improvements with it…
> Anyway, assuming it is advantageous, how can I handle this process?
> Shall I create the same tables and sequences as for jauth.db into a
> PostgreSQL schema and then edit profiles.ini.php with something like this?
> [jdb:jauth]
> driver=pdo
> dsn="pgsql:host=myhost;dbname=mydb;port=5432"
> user="myuser"
> password="mypwd"
> Thanks for any suggestion.
> Pietro
> AVVISO DI RISERVATEZZA Informazioni riservate possono essere contenute
> nel messaggio o nei suoi allegati. Se non siete i destinatari indicati
> nel messaggio, o responsabili per la sua consegna alla persona, o se
> avete ricevuto il messaggio per errore, siete pregati di non
> trascriverlo, copiarlo o inviarlo ad alcuno. In tal caso vi invitiamo
> a cancellare il messaggio ed i suoi allegati. Grazie.
> CONFIDENTIALITY NOTICE Confidential information may be contained in
> this message or in its attachments. If you are not the addressee
> indicated in this message, or responsible for message delivering to
> that person, or if you have received this message in error, you may
> not transcribe, copy or deliver this message to anyone. In that case,
> you should delete this message and its attachments. Thank you.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160217/b777fb43/attachment.html>
