[Qgis-user] Qgis/qgis server different layer scales to speed up server
Pietro Rossin
pierigis at gmail.com
Thu Feb 18 05:05:46 PST 2016
Hello qgis users
I hope this is the right place to ask for help in selecting the right
strategy to spped up the data served by qgis-server/lizmap
I have many polygonal features that can be seen at various zoom level
I want to serve them as a webis with qgis-server and Lizmap
Data are on a postgis server with all indexes set.
I had some suggestion to simplify the geometry let's say with 3-4
simplyfication level on the nodes of any polygon.
So I made 3 geometry column (orig - simpl1, simpl2 ecc) all the same kind of
the original one and each field with its index.
In simpl1, 2 3 ecc I calculate a simplification with
ST_SimplifyPreserveTopology(geometry , float) with increasing tolerance
based on original geometry.
Now I will like to use these geometry columns to load simpler features at
low zoom and richer ones at higher zoom level.
Is it possible to tell qgis to load a particular geometry column based on
the zoom level?
This thing should be also available in qgis-server and then in lizmap..
One solution I found was to make different view/query to load layers with
the desired geometry column and use visibility based on scale to show/hide
different layers..
Any other way?
Is it preferable to create views in Postgis or to query data by qgis db
manager?
Thanks for your help
Pietro
View this message in context: http://osgeo-org.1560.x6.nabble.com/Qgis-qgis-server-different-layer-scales-to-speed-up-server-tp5251409.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
