[Qgis-user] QGIS Server
    Clifford Snow
    clifford at snowandsnow.us
    Wed Feb 24 19:51:58 PST 2016
Jorge,
Thanks. I'm going to compare it to what I'm running now.
Clifford
On Wed, Feb 24, 2016 at 2:07 PM, Jorge Gustavo Rocha <jgr at di.uminho.pt>
wrote:
> Hi Clifford,
> Attached is my Apache configuration, both for the QGIS server and the QGIS
> client (it is the same file).
> The server is running on:
> http://sigum.di.uminho.pt/cgi-bin/qgis_mapserv.fcgi
> The client is avilable at:
> I hope it helps.
> Regards,
> J. Gustavo
> Às 00:44 de 20-02-2016, Clifford Snow escreveu:
>> Below is my sites-available config. If anyone else has a working copy
>> for Ubuntu's Wily I would appreciate a copy.
>> Apache loads with no error messages. Logs report mod_fcgid configured.
>> Yet when querying
>> localhost/cgi-bin/qgis_mapserv.fcgi?SERVICE=MMS&VERSION=1.3&REQUEST=GetCapabilites,
>> apache returns a 404 "The requested URL /cgi-bin/qgis_mapserv.fcgi was
>> not found on this server."
>> 001-qgis-server.conf
>>     <VirtualHost *:80>
>>        ServerAdmin webmaster at localhost
>>        DocumentRoot /var/www/html
>>        ServerName <localhost>
>>        ErrorLog ${APACHE_LOG_DIR}/qgis-server-error.log
>>        CustomLog ${APACHE_LOG_DIR}/qgis-server-access.log combined
>>        # Longer timeout for WPS... default = 40
>>        FcgidIOTimeout 120
>>        FcgidInitialEnv LC_ALL "en_US.UTF-8"
>>        FcgidInitialEnv PYTHONIOENCODING UTF-8
>>        FcgidInitialEnv LANG "en_US.UTF-8"
>>        FcgidInitialEnv QGIS_DEBUG 1
>>        FcgidInitialEnv QGIS_SERVER_LOG_FILE /tmp/qgis-000.log
>>        FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
>>       # FcgidInitialEnv QGIS_PLUGINPATH "/opt/qgis-server/plugins"
>>        # Needed for QGIS HelloServer plugin HTTP BASIC auth
>>        ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/qgis_mapserv.fcgi
>>        <Directory "/usr/lib/cgi-bin/qgis_mapserv.fcgi">
>>            AllowOverride None
>>            Options +ExecCGI -MultiViews -SymLinksIfOwnerMatch
>>            # for apache2 > 2.4
>>            Require all granted
>>            #Allow from all
>>            SetEnv QGIS_LOG_FILE /tmp/qgislog.txt
>>            AddHandler fcgi-script .fcgi
>>        </Directory>
>>          ErrorLog ${APACHE_LOG_DIR}/qgis-web-client-error.log
>>          CustomLog ${APACHE_LOG_DIR}/qgis-web-client-access.log combined
>>       </VirtualHost>
>> On Thu, Feb 18, 2016 at 11:35 PM, Luca Manganelli <luca76 at gmail.com
>> <mailto:luca76 at gmail.com>> wrote:
>>     On Fri, Feb 19, 2016 at 8:08 AM, Clifford Snow
>>     <clifford at snowandsnow.us <mailto:clifford at snowandsnow.us>> wrote:
>>     > Now I'm getting a .cgi-bin/qgis_mapserv.fcgi was not found
>>     Where is your qgis_mapserv.fcgi located? You should link to the
>>     cgi-bin directory (see your apache2 configuration)
>> @osm_seattle
>> osm_seattle.snowandsnow.us <http://osm_seattle.snowandsnow.us>
>> OpenStreetMap: Maps with a human touch
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
@osm_seattle
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160224/26bff676/attachment.html>
