[Qgis-user] layer variable not working in modeler
Kurt Menke kurt at birdseyeviewgis.com
Sat Feb 27 10:54:03 PST 2016
Hello everyone,
I am trying to develop a model in QGIS 2.13.0-Master, that will add an
attribute column populated with the layer name. I can do this in the
standard Field Calculator using the @layer_name Layer variable.
However, when I try repeating this in a model using the Field calculator
algorithm, it produces NULL output. I'm guessing this is syntax issue,
rather than a scoping issue, because creating a project level variable still
I have been putting the variable in the Formula line of the Field calculator
tool. For example: @layer_name
Should variables work in the Processing modeler? If so am I just using
incorrect syntax?
Thanks!
Kurt
Kurt Menke, GISP
Bird's Eye View
 <http://www.birdseyeviewgis.com/> www.BirdsEyeViewGIS.com
Work: 505-265-0243
Cell: 505-362-1776
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160227/e6fccd57/attachment.html>
