[Qgis-user] Custom form checkbox widget
McDonaldR
McDonaldR at angus.gov.uk
Wed Jan 13 06:01:25 PST 2016
Hi List
I have a table in PostGIS with a Boolean field which allows for TRUE/FALSE, t/f, true/false, y/n, yes/no, on/off, 1/0 values.
I have a custom form in QGIS for that table and the edit widget for that field is set to checkbox. In the checkbox widget settings there are two options for
* Representation for checked state:
* Representation for unchecked state:
The custom form only shows the correct value in the pop-up form if the values above are set to 't' and 'f' respectively. If I set them to any of the other options the checkbox in the form is always blank even though the value in the field in the table is populated with TRUE or FALSE.
So, the question is whether this is a Qt or QGIS enforced behaviour?
If it is, and the only options for checked/unchecked state are t/f, then shouldn't they be set by default?
I am using QGIS 2.12.2 on Win 7 32bit with PostgresSQL 9.2.14 and PostGIS 2.1.8.
Thanks in advance
Ross
Ross McDonald | GIS Data Coordinator | Resources Department, IT Division | Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk<mailto:mcdonaldr at angus.gov.uk>
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160113/fe3b4216/attachment.html>
