[Qgis-user] QGIS 2.12.3-1 crashes on startup - Arch Linux
Matthias Kuhn
matthias at opengis.ch
Thu Jan 21 13:35:39 PST 2016
Hi
On 01/21/2016 10:33 PM, Richard Duivenvoorde wrote:
> On 21-01-16 21:51, Enock Seth Nyamador wrote:
>> Hi QGISers,
>> Kindly help me out I've been trying to figure out what is prenventing my
>> QGIS from working as it used. Lot of web searches couldn't help either.
>> When I run it from terminal this is the error message I get:
>> Warning: loading of qgis translation failed
>> [/usr/share/qgis/i18n//qgis_en_US]
>> Warning: loading of qt translation failed
>> [/usr/share/qt4/translations/qt_en_US]
>> Warning: QCss::Parser - Failed to load file "/style.qss"
> Hi Enock,
> those warnings are 'normal', and not errors which would prevent QGIS
> from starting.
> please give more information about your setup:
> - which linux distro/version
> - which repo's or how did you install/compile?
And foremost, try to rename your $HOME/.qgis2 folder temporarily to
something else to see if it's a plugin or configuration issue.
Best
> etc etc
> Regards,
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
