[Qgis-user] perturb point locations
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed Jan 27 06:51:18 PST 2016
I remember a french made plugin made for heath sciences that had that option to fuzz data position within a certain radius. I can't look now because of my internet connection. I you can't find it, I can check tomorrow if you hail me. Look in mmqgis plugin, there could be something there also.
Hope this help
Nicolas
On Jan 27, 2016 09:40, "Richard Males [via OSGeo.org]" <ml-node+s1560n5247594h75 at n6.nabble.com> wrote:
I would like to perturb all the point locations on a layer by a random amount within a range, from say 100 feet to 500 feet. Each point should be individually perturbed with different values for the x and y, but the overall perturbation range will be the same for the layer. The purpose is to obfuscate actual locations in a data set. I have not been able to locate anything that will do this. I can use the Update All capabilities on the attribute table to get values for an attribute, e.g. attribute_x = $x+randf(100.0,500.0) but I am not clear on how to push this back to the actual x coordinate of the point. Any suggestions, including python scripting, plugins, or other approaches, will be welcome. Thanks in advance. Dick Males Cincinnati, OH USA
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/perturb-point-locations-tp5247594.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/perturb-point-locations-tp5247594p5247598.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160127/65d52532/attachment.html>
