[Qgis-user] General interest in geological support for QGIS?
John Harrop
jcharrop at gmail.com
Sat Jan 30 10:47:01 PST 2016
Since we have been talking about geological symbol fonts…
What is the level of interest in other geological tools? I would very much like to see the momentum in QGIS carry on into building tools in QGIS and/or PostGIS to support drilling, geochemistry and geophysics field surveys.
For example, I have run simple drill sections as “projections” with the data calculated in a spreadsheet. Recently I have been (enjoying!) processing magnetic surveys in R and building profiles for plotting in plan view along the survey lines. The tools are there to build a good exploration suite like those provided commercially for MapInfo and ESRI.
Any other interest in this? Should we be more formalizing a project?
John
> On Jan 30, 2016, at 12:56 AM, gene <martin.laloux at gmail.com> wrote:
> The solution we were using was a True Type font (Font marker symbol) with
> geological symbols (as ArcGIS with the geology ttf symbols). We cannot use
> directly this ESRI police ( FAQ: What are the applicable copyright
> restrictions on Esri fonts?"
> <http://support.esri.com/en/knowledgebase/techarticles/detail/32155 > ) but
> it is relatively easy to create a new True Type Font with geological symbols
> with FontForge <https://fontforge.github.io/en-US/> . You draw the symbols
> with a classical interface
> <http://osgeo-org.1560.x6.nabble.com/file/n5248101/fontforge2.jpg>
> and you generate the True Type Font (look at QGIS and fonts as symbols, use
> and creation with FontForge
> <http://www.portailsig.org/content/qgis-et-les-polices-de-caracteres-comme-symboles-utilisation-et-creation-avec-fontforge>
> , in French but the figures are universal). You can even copy/paste a SVG
> symbol as a new character of the font or export a character to a SVG file .
> You can change the color and the size of a character without problem and it
> is easy to distribute
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Geological-Map-Symbols-Continued-tp5248087p5248101.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
