[Qgis-user] SQL Updates on virtual layer shape file attribute failes
DelazJ
delazj at gmail.com
Sun Jul 3 03:52:16 PDT 2016
Hi
Stephan, why not use the Field Calculator (with a Case When statement or an
expression-based selection beforehand)?
Harrissou
2016-07-03 11:25 GMT+02:00 Stephan Weiser <stephan.weiser at gmx.com>:
> Hey there,
> I am using QGIS 2.14.1 (Essen). In order to create a city scenery for a
> Flight Simulator, I need to process shp-files.
> The shape files I use are the shape files of open street map. For a
> certain city loaded the shp file into QGIS with the name „buildings“. For
> the Flight Simulator I have to define several „classes“ of buildings using
> the „type“ attribute of a single shape. As the shape file I downloaded is
> only poorly descripted (most „types“ are NULL), I want to overwrite the
> „type“ Attribute with the proper names To make it easy for you, i have the
> following shape files als QGIS virtual layers:
> - „buildings“ (the downloaded shp file -> original layer with all
> Buildings)
> - „buildingsTypeA“ (a subset of „Buildings“ with target „type“
> „btA“)
> - „buildingsTypeB“ (a subset of „Buildings“ with target „type“
> „btB“)
> - „buildingsTypeC“ (a subset of „Buildings“ with target „type“
> „btC“)
> The „buildingType“ Layers have been created by selecting the proper shapes
> in „Buildings“ and copying them into a new virtual layer.
> As every building shape of A, B and C occur in „Buildings“ I tried to
> write a simple SQL update Statement like this. All the virtual layers have
> the same structure (osm_id, name, type, geometry)
> UPDATE buildings
> SET type = 'btA‘
> WHERE buildings.osm_id IN (SELECT osm_id from buildingsTypeA)
> The same should be done for buildingsTypeA and buildingsTypeA.
> When I exectute the Statement, I get an error: „near "update": syntax
> error“. Simple SELECT Statements work. To simplify it further I also
> noticed that e.g the following query resulted in the same error
> UPDATE Buildings
> Set type =‘abc‘
> WHERE buildings.osm_id = '12345567‘
> So my questions are:
> - Does the Database Manager Plugin for QGIS only Support Select
> Statements (Read Only)?
> - If yes, is there a different way to edit the data in batch mode?
> (round about 5000 buildings have to be updated)
> - Are there other ways to Access shp-files in a SQL-like manor to
> perform that UPDATE Statements?
> Hope you can help me out here.
> Best regards,
> Stephan
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160703/c6542db1/attachment.html>
