[Qgis-user] Colorize with values from attribute table
Richard McDonnell
richard.mcdonnell at opw.ie
Wed Jul 6 04:14:05 PDT 2016
Lene,
It will depend on your attributes and how you have set it up, but, under
*Layer Properties*, *Style* the colours can be set using the *Data
defined override* option (Form Icon) Click on this and select Edit, from
her you can create the variables you want. On the right you will see a
group called Colour, depending on how you specify your colour will
depend on how you use this. For example say you have RGB values in three
diferent columns, select *Colour* and then *colour_rgb* this will add
*color_rgba(* to your expression, then using *Fields and Values*, select
the appropriate Red, Green and Blue attributes from the table and close
the brackets you should have something like *color_rgba("red", "green",
"blue") *you will know it has worked, as the *Output Preview *on the
bottom left will display the RGB value.
Similarly, if you have a single column for your RGB (formatted
correctly) the same formula would be used, buy you would have a single
field (column) in the expression.
Hope this is clear!
Regards,
Richard.
On 05/07/2016 10:53, Lene Fischer wrote:
> Hi,
> Looking for a tutorial for colorizing with values from the attribute
> table.
> I have the RGB values, but can´t find a way to use it…
> Forund this old one – but the functions has changed a lot since.
> http://shreshai.blogspot.dk/2014/10/display-with-color-symbology-from-data.html
> Ragards
> *Lene Fischer*
> Associate Professor
> *University of Copenhagen*
> Department of Geoscience and Natural Resource Management
> Forest and Landscape College
> Nødebovej 77a
> 3480 Fredensborg
> Denmark
> MOB +45 004540115084
> _lfi at ign.ku.dk_ <mailto:lfi at ign.ku.dk>
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160706/06dea8b9/attachment.html>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160706/06dea8b9/attachment.gif>
