[Qgis-user] Shapefile with file .cpg(codepage)
Neumann, Andreas a.neumann at carto.net
Thu Jul 7 07:51:26 PDT 2016
I wonder why this is not the default? If a .cpg file is present, one can
assume that the information is correct. Probably in some edge cases it
may be false, but in the majority I assume the .cpg files to contain
correct information.
Andreas
On 2016-07-07 16:17, Claas Leiner wrote:
> Hi,
> QGIS uses the .cpg file when you deselect the Option  "Ignore shapefile encoding declaration"
> You find it:
> Settings > Options >  Data Sources
> Then there are no encoding-problems tu use QGIS with Shapefiles in in a mixed environment.
> Cheers
> Claas
> GKG-Kassel - Dr.-Ing. Claas Leiner
> QGIS-Support und mehr
> Geodatenservice, Kartenwerkstatt &
> GIS-Schule Kassel
> Wilhelmshöher Allee 304 E
> 34131 Kassel
> Tel. 0561/56013445
> claas.leiner at gkg-kassel.de
> http://www.gkg-kassel.de
> Unterstützen Sie QGIS
> QGIS-DE e.V. | http://qgis.de
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160707/7de91442/attachment.html>
