[Qgis-user] QGIS crashes when printing to svg format
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Jul 8 20:06:52 PDT 2016
Definitely not a laptop cpu or memory problem. I run Qgis with a window7 core 2 cpu with no trouble for everything except Lidar.
Try using the simplesvg plugin to save the shape file or maybe try a "save as" for the layer.
Don't try to save a layer with the print composer. If you have funny crashes, try deactivating all the plugins except to one you really need.
https://plugins.qgis.org/plugins/simplesvg/
On Jul 8, 2016 20:48, "Phillip Money [via OSGeo.org]" <ml-node+s1560n5275500h61 at n6.nabble.com> wrote:
I have a 50 MB shapefile. I am trying to import it into Illustrator. When I try printing to an svg file from the Print Composer, QGIS crashes. I am using QGIS Essen 2.14.3. I have tried lots of different things: simplifying the geometry (QGIS crashes) trying to print to a postscript file (will only print to a prn file, which Illustrator can't read) installing Cute PDF (doesn't really work in Illustrator) I am using a laptop with Windows 10, 32 bit and 4gb of RAM. Will upgrading to a new machine with 8gb of RAM and 64-bit windows 10 make any difference? I can't afford a new laptop, but I need to output to Illustrator so will probably have to bite the bullet. Any help would be appreciated. Regards Phillip Money
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/QGIS-crashes-when-printing-to-svg-format-tp5275500.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-crashes-when-printing-to-svg-format-tp5275500p5275505.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160708/b1c2a8eb/attachment.html>
