[Qgis-user] Spatial autocorrelation with local moran index with Python or QGIS
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Jul 11 19:20:52 PDT 2016
That's a question for R that you can access with Qgis but personally, I find it just easier to use R directly. Saga, may have a local Moran and probably Grass. Open the processing plugins and search for the geospatial statistics and a few will pop up from Grass and Saga.
A very easy way would be to use CrimeSat software. It works with shapefiles, has tons of spatial statistics. I am 95% sure it has a local Moran or other autocorrelation statistics. It's well documented also. Just Google it. It's open source.
Nicolas
On Jul 11, 2016 9:01 PM, "carlos hernandez [via OSGeo.org] " <ml-node+s1560n5275834h15 at n6.nabble.com> wrote:
Hello, I wanted to know if someone of you have worked with PySAL or spatial autocorrelation with local moran index? i just need it becouse i have a vectorial layer of points and i want to know the local moral index for each point. in other way if you know how to clean not spatial autocorrelated inliers of a vectorial liyer of points with python or QGIS i will be so gratefull. Yours sincerely. Carlos
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Spatial-autocorrelation-with-local-moran-index-with-Python-or-QGIS-tp5275834.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Spatial-autocorrelation-with-local-moran-index-with-Python-or-QGIS-tp5275834p5275841.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160711/cf7d0f35/attachment.html>
