[Qgis-user] FW: Couldn't load QGIS utils
Carlos Cerdán
sig.upagu at gmail.com
Tue Jul 12 07:24:59 PDT 2016
Thank you Pim
2016-07-12 9:23 GMT-05:00 Carlos Cerdán <sig.upagu at gmail.com>:
> Yes, Processing WAS enabled, and it was broken!. I've uninstalled it and
> now all is fine: Processing plugin was in conflict with Processing core.
> So... it affects to updates from 2.14 to 2.16. All of you are advised:
> after updating, you must unistall processing plugin, cause now it's part of
> QGIS core.
> Good QGISing!
> Carlos Cerdán
> 2016-07-12 8:50 GMT-05:00 Richard Duivenvoorde <rdmailings at duif.net>:
>> On 12-07-16 15:29, Carlos Cerdán wrote:
>> > There is an issue that can be related with this: ftools disappeared in
>> > QGIS 2.16 (Ubuntu 16.04. Don't know about windows); so we still can't
>> > do basic vectorial geoprocessing. I guess it's under revision.
>> I do not think it is related.
>> Do you have 'processing'-plugin enabled?
>> Because that is the one that provides all vector algorithms nowadays. If
>> you van processing disabled, you will not see them in vector-menu.
>> Else, try to start qgis from command line in a new configuration:
>> qgis --configpath /tmp/foo
>> so you will have a fresh setup (and processing enabled by default).
>> Regards,
>> Richard
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160712/f70c589f/attachment.html>
