[Qgis-user] FW: Couldn't load QGIS utils
Matthias Kuhn
matthias at opengis.ch
Tue Jul 12 08:45:23 PDT 2016
Hi Carlos,
Processing has been part of core for a long time already.
It has also been shipped as a separate plugin in parallel which caused a
lot of troubles like you noticed now.
This is no longer available and you are absolutely right in recommending
removal if it has been installed from this sources.
Matthias
On 07/12/2016 04:49 PM, Carlos Cerdán wrote:
> Thank you very much Matthias... I've just discovered it, and found that
> Processing is now part of the core of QGIS, so if someone is updating
> from 2.14 or less, must unistall the processing plugin to avoid
> conflicts with Processing core (sorry if terms are not correct).
> Now, all is fine... I hope.
> Regards from Peru
> Carlos
> 2016-07-12 9:25 GMT-05:00 Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>>:
> Hi Carlos,
> As far as I know all functionality available in ftools is available in
> processing.
> There was a lot of duplicated code which was unmaintained so the
> decision was to put the full focus on one tool and avoid doing work
> twice.
> If there's anything missing, please report it!
> Regards
> Matthias
> On 07/12/2016 03:29 PM, Carlos Cerdán wrote:
> > There is an issue that can be related with this: ftools disappeared in
> > QGIS 2.16 (Ubuntu 16.04. Don't know about windows); so we still can't
> > do basic vectorial geoprocessing. I guess it's under revision.
> > Developers please light us...
> > 2016-07-12 6:33 GMT-05:00 Pim Verver <pim at travelingo.nl <mailto:pim at travelingo.nl>
> > <mailto:pim at travelingo.nl <mailto:pim at travelingo.nl>>>:
> > Hi all,____
> > __ __
> > Yesterday I installed a 64 bits version of QGIS 2.16 and after
> > startup I got the following popup. After that QGis seems to be
> > working okay (apart from the python disabling). Is there an obvious
> > solution for this problem. I tried both the advanced and the express
> > install, but no luck so far.____
> > __ __
> > Couldn't load QGIS utils.
> > Python support will be disabled.____
> > Traceback (most recent call last):
> > File "", line 1, in
> > File "C:/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line 21, in
> > standard_library.install_aliases()
> > File
> > "C:\OSGEO4~1\apps\Python27\lib\site-packages\future\standard_library\__init__.py",
> > line 483, in install_aliases
> > import test
> > File "C:\OSGEO4~1\bin\test.py", line 3, in
> > for layer in iface.mapCanvas().layers():
> > NameError: name 'iface' is not defined____
> > Python version:
> > 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
> > QGIS version:
> > 2.16.0-Nødebo 'Nødebo', d0b3e39
> > Python path:
> > ['C:/OSGEO4~1/apps/qgis/./python', u'C:/Users/Pim/.qgis2/python',
> > u'C:/Users/Pim/.qgis2/python/plugins',
> > 'C:/OSGEO4~1/apps/qgis/./python/plugins',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\matplotlib-1.3.1-py2.7-win-amd64.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\nose-1.3.3-py2.7.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\tornado-4.0.1-py2.7-win-amd64.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\backports.ssl_match_hostname-3.4.0.2-py2.7.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\certifi-14.05.14-py2.7.egg',
> 'c:\\osgeo4~1\\apps\\python27\\lib\\site-packages\\python_dateutil-2.1-py2.7.egg',
> > 'C:\\OSGEO4~1\\bin\\python27.zip',
> > 'C:\\OSGEO4~1\\apps\\Python27\\DLLs',
> > 'C:\\OSGEO4~1\\apps\\Python27\\lib',
> > 'C:\\OSGEO4~1\\apps\\Python27\\lib\\plat-win',
> > 'C:\\OSGEO4~1\\apps\\Python27\\lib\\lib-tk', 'C:\\OSGEO4~1\\bin',
> > 'C:\\OSGEO4~1\\apps\\Python27',
> > 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages',
> > 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\PIL',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\jinja2-2.7.2-py2.7.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\markupsafe-0.23-py2.7-win-amd64.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\pytz-2012j-py2.7.egg',
> > 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\win32',
> > 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\win32\\lib',
> > 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\Pythonwin',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\Shapely-1.2.18-py2.7-win-amd64.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\wx-2.8-msw-unicode',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\xlrd-0.9.2-py2.7.egg',
> 'C:\\OSGEO4~1\\apps\\Python27\\lib\\site-packages\\xlwt-0.7.5-py2.7.egg']____
> > __ __
> > Kind regards,____
> > __ __
> > Pim Verver____
> > __ __
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> <mailto:Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>>
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
