[Qgis-user] QGIS 2.16 cannot use WMS services as 2.14 did
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Jul 14 06:44:04 PDT 2016
Hi Mats,
I don't have any issues with 2.16.0 and WMS connections.  However I have
been in your same shoes before, and besides the clearing-the-QGIS-cache
trick, I found the best way to examine this is to use an external tool
(Fiddler) to get the exact WMS request that is generated by QGIS.  It
takes a little effort to set this up, but it really helps to find out
why a single server won't load in QGIS.  Then you can take that full
request and paste it into the ticket, for the QGIS team to examine.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-07-14 6:31 AM, Mats Elfström wrote:
> Hi!
> For some reason, existing projects and WMS connections from 2.14.3 does
> not work in 2.16.
> Capabilities download fails, or I get Map request failed
> [error:Connection closed.
> Is there some fundamental change in 2.16 that needs another setup or
> other parameters for WMS?
> Most of the the services I use needs basic authorization, but that seems
> to work. The error occurs as the map is to be rendered.
> We rely heavily on WMS for background maps, so this is a showstopper for
> v 2.16.
