[Qgis-user] package dependency conflict QGIS 2.14.4
Otto Dassau
dassau at gbd-consult.de
Fri Jul 15 07:38:35 PDT 2016
Hi Carlos,
thanks for your suggestion, but this doesn't seem to help, probably because
qgis packages depend on libgeos-c1 and libgdal1h
see http://qgis.org/ubuntugis-ltr/lists/qgis2_trusty_main_amd64_Packages
and libgdal1h : Depends: libspatialite5 (>= 2.4.0)
and libspatialite5 : Depends: libgeos-c1v5
and this causes the dependency problem: libgeos-c1v5 breaks libgeos-c1 as
the error message shows below.
Is there another workaround or is it necessary to change package
dependencies in the build environment?
Regards,
Otto
Am Fri, 15 Jul 2016 08:52:23 -0500
schrieb Carlos Cerdán <sig.upagu at gmail.com>:
> Hi Otto:
> Try uninstalling all QGIS stuff, even GRASS. After that, clean your
> repositories and left just your prefered one; update and install again
> QGIS.
> That workaround was my salvation in similar cases (Ubuntu 1x.04 and QGIS
> 2.x).
> All the best
> Carlos
> 2016-07-15 8:27 GMT-05:00 Otto Dassau <dassau at gbd-consult.de>:
> > Hi Jürgen,
> > yes, entry in /etc/apt/sources.list is
> > deb http://qgis.org/ubuntugis-ltr trusty main
> > deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu trusty
> > main
> > error message is:
> > The following packages have unmet dependencies:
> > libgeos-c1v5 : Breaks: libgeos-c1 (< 3.4.2-8~) but 3.4.2-4ubuntu1 is to
> > be installed E: Error, pkgProblemResolver::Resolve generated breaks,
> > this may be caused by held packages.
> > Is it because there are still dependencies building and not yet
> > available?
> > Regards,
> > Otto
> > Am Fri, 15 Jul 2016 15:19:08 +0200
> > schrieb Jürgen E. Fischer <jef at norbit.de>:
> > > Hi Otto,
> > > On Fri, 15. Jul 2016 at 15:09:29 +0200, Otto Dassau wrote:
> > > > trying to update QGIS packages (2.14.4) from ubuntgis-ltr repository
> > > > on ubuntu 14.04 gives a dependency conflict.
> > > Did you also add the ubuntugis repository?
> > > Jürgen
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
