[Qgis-user] Define custom projections using a script
    Régis Haubourg
    regis.haubourg at gmail.com
    Fri Jul 15 07:39:49 PDT 2016
Hi, projections are stored in SQLite db's. Some python script will do the
trick for sure.
Régis
Le 15 juil. 2016 4:02 PM, "Tudorache, Marian" <Marian.Tudorache at navcanada.ca>
a écrit :
> Anybody could help me with this?
> Thanks,
> Marian
> *From:* Tudorache, Marian
> *Sent:* July-13-16 12:21 PM
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Define custom projections using a script
> Hi everyone,
> I have a big list with custom projections that have to be added in QGIS.
> I know how to do this using Custom CRS from Setting menu. However it would
> be a time consuming job to add them one by one but then I have to
> distribute them to around 50 computers.
> In time these projections will be updated with new parameter values. No
> need to explain how long job will be if this is done manually.
> I am looking to a possible file in QGIS where those custom projections are
> store so I can modify it using a python script.
> Can someone tell me how and where those projections are stored in QGIS?
> Thanks,
> Marian
> This electronic message, as well as any transmitted files included in the
> electronic message, may contain privileged or confidential information and
> is intended solely for the use of the individual(s) or entity to which it
> is addressed. If you have received this electronic message in error please
> notify the sender immediately and delete the electronic message. Any
> unauthorized copying, disclosure or distribution of the electronic message
> is strictly forbidden. NAV CANADA accepts no liability for any damage
> caused by any virus and/or other malicious code transmitted by this
> electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint
> peuvent contenir des renseignements privilégiés ou confidentiels destinés à
> l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si
> vous avez reçu ce message électronique par erreur, veuillez en informer
> l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation
> ou distribution du présent message électronique est strictement interdite.
> NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout
> virus ou autre programme malveillant transmis par ce message électronique.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160715/4218758a/attachment.html>
