[Qgis-user] Importing CSV files
Chris Crook
ccrook at linz.govt.nz
Sun Jul 17 11:45:10 PDT 2016
Hi Philip
As has been pointed out the problem is that the "numbers" in your file are not numbers, as the have a '%' character included. The delimited text reader only handles things that look like numbers, and at the moment things like '5%' don't come into that category (this could be changed but at the moment it isn't built to recognize the percentage sign as part of a number). So it reads these fields a text string fields.
In the case of your file though there is a workaround, which is to treat the percentage as part of the delimiter, and to use a regular expression to define the delimiter. The attached screenshot shows the settings that you can use to read the file. The important things to notice are the use of a regular expression as a delimiter and the expression used [\%\,]+, which translates as "any string of consecutive percentage signs or commas".
I'd agree that this is not even slightly obvious, but it does work!
Cheers
Chris
________________________________________
From: Qgis-user [qgis-user-bounces at lists.osgeo.org] On Behalf Of Phillip Money [phillip.money at hotmail.com]
Sent: 16 July 2016 01:03
To: Werner Macho
Cc: qgis-community
Subject: Re: [Qgis-user] Importing CSV files
Thanks Werner and Richard for your help so far. I will have to pursue this tomorrow as it is late here in Australia.
I will respond tomorrow.
Phillip
Date: Fri, 15 Jul 2016 14:53:03 +0200
To: phillip.money at hotmail.com
CC: richard.mcdonnell at opw.ie; qgis-user at lists.osgeo.org
Find attached the working csv and csvt file - And remember - this csv is now NOT to be loaded with delimited text but rather as a "normal" vector layer.
regards
Werner
On Fri, Jul 15, 2016 at 2:26 PM, Phillip Money <phillip.money at hotmail.com<mailto:phillip.money at hotmail.com>> wrote:
Richard and Werner.
I left the csvt file as "String", "Integer", "Integer", "Integer". I converted the percentages to numbers. It still didn't work. At Richard's suggestion, I converted the csv file to a text file and it worked. I can't understand why it didn't work with a CSV file. I am using QGIS Nodego. Thanks for your help, but I am still stumped about the csv file.
Phillip
From: werner.macho at gmail.com<mailto:werner.macho at gmail.com>
Date: Fri, 15 Jul 2016 14:17:35 +0200
To: richard.mcdonnell at opw.ie<mailto:richard.mcdonnell at opw.ie>
CC: phillip.money at hotmail.com<mailto:phillip.money at hotmail.com>; qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Hi Richard,
Surely QGIS is able to import it - but you forgot about that sentence in his first post:
"I have set up a csvt file with "String", "Integer", "Integer", "Integer" "
Using a csvt is sometimes very handy - but as already written "86%" is unfortunately no integer ;)
regards
Werner
On Fri, Jul 15, 2016 at 2:14 PM, Richard McDonnell <richard.mcdonnell at opw.ie<mailto:richard.mcdonnell at opw.ie>> wrote:
Phillip,
I have copied out what you sent, paste it into notepad and saved it as a txt file. I then imported it into QGIS using Add delimited Text Layer, making sure to select Custom delimiters, and selecting Semicolon.
One other thing I done was select No geometry.
This has worked perfectly see attribute table below
[cid:part1.00080202.07000508 at opw.ie]
I hope the above settings work, I am running QGIS 2.14 by the way, shouldn't make a difference though.
Regards,
Richard.
On 15/07/2016 13:03, Phillip Money wrote:
Richard,
I am using Add delimited Text Layer.
Here is a snippet of the data.
LGA_NAME;Non-Indigenous;Aboriginal;Torres Strait Islander
Albury (C);93%;2%;0%
Armidale Dumaresq (A);88%;6%;0%
Ashfield (A);93%;1%;0%
Auburn (C);93%;1%;0%
Ballina (A);93%;3%;0%
Balranald (A);87%;6%;0%
Bankstown (C);94%;1%;0%
Bathurst Regional (A);91%;4%;0%
I had the data separated by commas, but changed it to semi-colons. Neither worked. I also change the date to numerical format as in .93. That didn't work either.
On 15 July 2016 at 22:00, Richard McDonnell <richard.mcdonnell at opw.ie<mailto:richard.mcdonnell at opw.ie>> wrote:
Phillip,
Can you supply a sample of the data, also what version are you running of QGIS.
The other thing is are you using Add delimited Text Layer or are you just loading the CSV directly?
Regards,
Richard.
On 15/07/2016 12:29, Phillip Money wrote:
I have a CSV file with four columns. The first column is text, and the succeeding columns are percentages. I have set up a csvt file with "String", "Integer", "Integer", "Integer" When I import the file into QGIS as a delimited text layer, QGIS strips out all the percentages. They come in as null values. I have tried a lot of things, but can't get past this.
For example, I have tried converting the percentages to numbers and bringing them in that way; same thing happens.
I would appreciate any help.
Regards
Phillip Money
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Richard McDonnell
GIS Specialist PgD GIS AssocSCSI
OPW FRM Data Management
52 Stephens Green, Dublin 2.
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
[http://www.opw.ie/en/media/opw-email-banner.png]<http://www.opw.ie/>
Email Disclaimer: http://www.opw.ie/en/disclaimer/
Richard McDonnell
TEL: 01 6476543
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
Type: image/jpeg
Desc: dlt_settings.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160718/81a61c35/attachment.jpg>
